Distributor shock!?
BlackDynamite
KTHXBIA
Feb 24, 2007
714
Oregon
Ok a few days ago, before i went to work, i started the car and popped the hood(Holding it up because my shocks just went out) and was checking everything under the hood doing a quick check just for the heck of it.
Well i made sure the oil, radiator, etc. caps were on tight and went to make sure the the spark plug wires were on nice and tight and then......ZAAAPPPP.....
I get the baJesus shocked out of me, making both of my arms flinch hard into my chest and making me fall over and drop the hood....is this normal?:sarcasm:
Ps. The wires were on all the way and still got shocked
BlackDynamite
KTHXBIA
Feb 24, 2007
714
Oregon
Yeah, i just didnt think it would do that...none of my other cars have done that...
Well i mean, there was this cap that came on the car that went over the distributor....but i never put it back on.....doh....;]
Oh my dads an electrician and was laughing at me as i'm laying in the yard...he saw what happened through the window and said it looked like i got hit by a taser.....then i started laughing...
cuel
1,536
Baytown, Texas
lol. Been there, done that. Adjusting distributors to set the timing. I wear rubber gloves, and make sure I'm not too close to the wires, now. Bet you won't check the wires with the car running again...
MassSupra89
Almost done.
Nov 3, 2005
1,707
MA
Happened to an instructor of mine, grabbed a plug wire and went right through him... Just be glad you weren't leaning on the fender of a truck and were grounded via your crotch like him. Lol.
BlackDynamite
KTHXBIA
Feb 24, 2007
714
Oregon
It happened to me once before but i thought it was a fluke and it only barely popped me....but you're right, i won't do that again....
Jaguar_5
It's ALIVE!
Feb 7, 2006
1,468
Seattle
LMAO
I've done exactly that before, lesson learned! :biglaugh:
Wasn't enough of a zap to knock me over though lol :)
Figit090
Fastest mk3 GT4 1/4 mile!
Jan 7, 2006
1,835
Humboldt County
ah, haha...man thats funny.
the other day i was removing a sparkplug wire (testing for RK) and I realised just how readily the sparks will jump a good 2-3 inches. then thought *AHH shit! * and slipped it back on.
how much do rubber gloves actually help? and how thick, the white thin ones or the heavy-duty yellow ones?
I was just wondering because sparkplug wires are coated in rubber so...
cuel
1,536
Baytown, Texas
I wear nitrile gloves at work anyway, to keep all the oil and crap off my hands. As far as keeping you from getting shocked, I don't know if they add enough insulation, and not gonna grab a wire to find out. Should make my hand a little less conductive, though. Electricity is kind of like water, in that it will take the path of least resistance. The wires are coated in rubber, but all it takes is a pin hole from someone grounding them out to test for spark, and you have enough to get bit.
Pulling the wire, on the other hand, lets the spark loose from the cap. I have a special pair of plastic plug wire pliers for pulling them. You can pull the wire up a few inches, and it'll still spark. Nice thick bolts of electricity, to, like miniature lightning.
ValgeKotkas
2,224
Over the pond
^Yeah, did that lightning :D bzzztbzzt :) Luckily didn't get bit, though mechanics beside me laughed at said to touch the wires with hands :D
jetjock
creepy-ass cracka
9,439
Ignition secondary voltage will rise to whatever it takes (within it's design limit) to jump the plug gap. That means when it's connected to the plug it only needs to go to around 15,000 volts to ionize the gas mixture. Once the plug fires voltage falls to about 5,000 for as long as the spark remains.
However, the system is capable of around 50,000 volts. Should you pull a wire off that's what it'll go to on the next firing and that's what you'll get hit with. The moral of this story is if you're going to mess with the ignition system do it with the plugs connected ;)
st2b
589
Versailles (Lex) Ky
I was replacing the starter, hit the wrench from the pos to the ground, and my hand felt like shit for like 3 days.
Nothing that bad, I think the worst part was my friend's chest injury (Laughing too hard)
Apparently I couldn't stop making funny faces... Oh well.
