Disc Rotor change
swissboysupra
15
Utah
I am a total newbie to cars but am enjoying doing some work on my 1990 Supra. Bought some Powerslot rotors to replace my stock. First, I had the hardest time removing the stock one. Banging the back like crazy until they finally came off. I can't get the new Powerslot rotors to slide on. The bolts come through ok and everything but I can't slide the rotor in. And of course I don't want to force it on. What can I do about this? Is there too much rust on my wheel?
Grab a sheet of sandpaper fold it lengthwise a few times so you have a strip then wrap it around the hub and sand like you're buffing a shoe.
Turn the hub a bit and repeat until you've done the full 360 degrees.
Just DON'T sand in one place too long and it'll be fine.
swissboysupra
15
Utah
Thanks IJ. I will give that a try!
swissboysupra
15
Utah
Zumtizzle;1088585 said:
Also Remove and Grease the sliders with CRC Synthetic Grease, (it has moly in it)
Don't use wheel bearing grease. :)
Finally back from my vacation so I can finish up this project.. Where are the sliders and how do they remove?
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
oowee623;1100968 said:
next time on the rears, take you caliper bolt and screw it into the holes on the rotor to pull it out. thats what its there for
it surprises me that more people don't figure this out
Don't ever beat on the rotor to try and remove it.
You can damage a hell of a lot by doing that. Bearings, suspension, rotor, studs...
Keros
Canadian Bacon
Mar 16, 2007
825
Calgary
IJ.;1101433 said:
From memory the holes are tapped m6x1 so which calliper bolt fits?
Agreed, I don't think any of the brake caliper related bolts would have fit, as the thread is too fine. Was a while ago though...
I used two random bolts that were sitting on my work bench. Anyway, yes, that is the proper way to remove a rotor ;)
