Van Diesel said:probably since it doesn't blow up.
With the higher comp ratio it should.Ric said:Doesn't the 1JZ make more WHP with the CT26 then the 7M? lol
JustAnotherVictim said:With the higher comp ratio it should.
socalguy said:The compression ratio is the same. 8.5:1
JZ=8.5:1socalguy said:The compression ratio is the same. 8.5:1
Oh and no.Ric said:No, he ment that the JZ has higher compression due to no BHG
huh????tturnpaw said:ok your best bet would be to use a manual boost controller (about $50) and turn it all the way down. It may run 1psi but thats better than where youre at. Its cheap, easy, and little work involved. BUT GO SINGLE!!!
tturnpaw said:it has to bleed the signal back to the wastegate for it to see anything.
