I disagree. 370 can and has been done on stock twins and it doesn't necessarily have to be something they could only do for a short time.
Prettyazznouka said:Thats not bad at all.... I think ill just save and go single the right way. 460whp thats niceeee
At what power range does the w58 give out? It has almost 150k on it im assuming unless it was replaced before
Intake, 3" turbo back exhaust, 440cc injectors (if not 550s), walbro, afpr, boost controler, cams, cam gears, front mount and a good piggy back that can control timing and a bulletproof tune.Prettyazznouka said:How can i make that on stock twins?
foreverpsycotic said:Intake, 3" turbo back exhaust, 440cc injectors (if not 550s), walbro, afpr, boost controler, cams, cam gears, front mount and a good piggy back that can control timing and a bulletproof tune.
Prettyazznouka said:If thats the case... why doesnt everyone go that route? Why does everyone say "the twins are garbage just go single, they cant hold high boost"
white1jz90 said:PHP:![]()
Prettyazznouka said:At what power range does the w58 give out?
OneJoeZee said:Because that's getting pretty close to their limit, they're a pain in the ass tod eal with, and you're wringing the twins neck at that level.
That kind of power can be done easy with a single while giving you a much simpler setup and potential for alot more.
And not everyone says the twins are garbage and they can't hold high boost. They can but they're still relatively unreliably regardless of how much boost you're running.
gravesdu_99 said:Hey I got an easy question for you. With the manifold from driftmotion. How did the 7m downpipes fit. I have a bic divorced ddp right now and I really don't think that I want to get rid of it. Plus if you want to upgrade you can also go to the boss turbos later.
new parts list for the single
manifold from driftmotion $330
boss turbo from HPF $1500 with oil lines
BIC divorced downpipe if you don't have one $450
Well over 400 whp with supporting fuel and management.
foreverpsycotic said:IIRC Aaron posted earlier that you would not be able to run anything bigger than a modified ct26. There is simply not enough room for a BOSS, JT or 20g bolt-on.
