differential question #2
Atsushi7mgte
203
Oahu, Hawaii
so i was supposed to pick up a NA lsd from my friend but he sold it already so im just gonna weld my diff.
after i get the spiders welded am i going to have to reshim it and set the backlash when i put it back together or can i just keep track of my old shims??
87supraguy
808
Tucson, az
i would just recheck the tolerances again to ensure everything is within specs... either way if you use the old shims or not... a diffs no fun if it locks up (in a bad way) cause we got lazy
Supraflymk3
Supraman
Dec 17, 2005
272
Neenah, Wisconsin, United States
I don't recommend welding a diff unless you're using it for drifting. They suck for daily driving. If you do, do it make sure you use atleast a 220 welder. I have built alot of Jeeps and welded a few diffs. The best way to make it really strong is throw chunks of metal in the open areas and weld the shit out of it.
87supraguy
808
Tucson, az
agreed...
---------- Post added at 02:23 PM ---------- Previous post was at 02:21 PM ----------
if it's a true LSD ... shit just leave it alone.... shit if your gonna weld an LSD dif i'll trade you my NON-LSD for your LSD... you can weld that one up..... i'm serious... cause i want a LSD
Atsushi7mgte
203
Oahu, Hawaii
nooo i dont have a LSD. And i know all the pros and cons of a welded diff. My supras not a full daily driver cause i got a truck that gets wayyyy better gas mileage.
And of course im welding my diff to drift...why else would i be welding it lol.
