So ever since i got my full 2.5 IC hard piping and my Sparco replica IC, ive noticed different sounds. When ever I boost say round 6 PSI or higher (around that PSI im not sure) I hear a pssshh ch-ch-chh sound when i shift gear. This is compression surge right? And also if i boost I can here a slight whistling sound and at high boost ill hear a clear air whistle sound, like if the By pass valve was leaking.
The whistle air sound I use to here it before i did the IC pipin/IC mods, ever since i raised the boost level. So i really dont think its a boost leak. It also seems to hold boost fine......
Is it time for an aftermaket BOV?
2.5 IC hard piping
Spearco replica IC
shimmed wastegate at 10 psi
stock By pass valve
2.5 IC hard piping
Spearco replica IC
stock By pass valve
