Differences in jdm and usdm 7M-GTE
Suprafast0422
107
Maryland
Im swapping in a jdm 7m, aside from the oil pres. sender and lack of egr, is anything else different that i should take note of? are any of the vacuum lines different?
figgie
Twin Cities, Minnesot-ah
Yep
Do not run "no EGR" on a US TCCS as it was tuned with EGR in mind ;)
92nsx
2,957
Clearwater, MN
The throttle body is different (U.S. has more ports on it). Also the BVSV (blue sensor thing on the coolant neck with 2 vac. hoses going to it) doesn’t exist on the JDM so also swap that.
I have hever had to swap the oil pressure sensor on my past JDM's but maybe I was just lucky.
That is all I can think of for now
