So the rebuild by the so called pro did not go well, idiot re used crush sleeve and it made a terrible hum on accel and decel. He took diff apart again and cut down on one of the side shims, and while this has dramatically reduced the hum on accel, the decel hum is still noticable. He will have another go at it, but if it isn't solving the issue, I am gonna take it on myself.
So I have few questions:
1. How much does the crush sleeve actually crush? I ask this as I plan to make my own hard sleeve to replace the crush sleeve, but need to know a ball park value of how much longer should I make this hard sleeve over the length of the existing crush sleeve, my guess is 1 to 2mm ?
2. Does the crush/hard sleeve preload effect the pinion depth ? If i get a good preload but my pinion depth is off what are my options ?
3. I am guessing I would need some thin shims for pinion and carrier bearings, any aftermarket shops I can buy some thin shims ?
4. How do I load the ring gear when I want to check the contact pattern ?
5. All 4 bearings are new but they have some use since i drove the car around (My guess 500 to 1000km), when re setting preload should I use values for used bearings or new bearings ? I am also guessing I shouldn't need to remove the bearings or the outer races.
Diff is an open diff so my guess is I shouldn't need to mess with whats inside the carrier.
Thanks in advance.
Thanks in advance.
