Thanks for the part #. Only $1 less than Toyota but $6 is $6 AND NAPA is much closer to the house.
I'm ordering the alternator today and will be rewiring the CPS when I install the alternator. If it still stumbles at idle I'll replace the injector seals again just because. It would actually make sense though as it happened right after a good boost run and only a post TB leak would cause this (known from experience as I had the 'fender box' on the IC piping literally blow apart while driving at 12 psi and was able to make it 1/4 mile to a parking lot, idled perfectly).
edit: Ordered the alternator from DM. A freshly rebuilt 140 amper should hold much better than a 20 yo 70.
