Guys i today while i was driving i got code 25 running lean again. I know a few of you are going to tell me to change my fuel pump, but according to the test's i performed under boost, the fuel pump seems to be doing its job. Right? I reall want to find the real problem to this. The test and results i got are in the my other posts in this thread.
So i know the fuel pump is good (pressure that is), fuel pressure regulator, im getting good pressure at idle and under load. I still loose the pressure when i turn off the engine.
The O2 sensor is like a few months old, Coolant Temp Sensor is a few months old (Toyota ECT), new fuel filter, i know i have good fuel pressure while under load. I also had the injectors cleaned while on the car.
So i was wondering is that maybe my injectors need to be removed from the engine. So that way they can fully clean the injectors in and out?
Or what else can i check?
I really want to get to the bottom of this problem, I appreciate your help. Thanks
