Did a boost leak test..Leaking ISC
suprafanatic
1,607
Greenwood, IN
I just did a boost leak test yesterday and couldnt believe how many boost leaks i found. I had boost leaking around the first two injector O rings, A leak out the screw on the BOV, a leak from a T bolt clamp, a leak from some Vac. T fittings. Then the biggest we found was coming from the ISC. As soon as we started to compress air into the intake it came right back out the ISC hose. The car would only hold like a pound of boost. So my question is, is the ISC suppose to leak boost back into the intake pipe? or is the diaphram behind my ISC shot? If its not suppose to do this where can i get a new diaphram? or what else could i do for now to fix this leak? I got all the others fix. Thanks
The dealer. It's actually a check valve that prevents reverse flow through the ISCV. It is in a recessed area in the manifold flange under the ISCV.
suprafanatic
1,607
Greenwood, IN
ya i know where its located i took it out and looked at it. I'll see if i can order one from somewhere, could i get a different kind of check valve for now to put in the rubber hose? Like a PVC check valve?
TurboStreetCar
Formerly Nosechunks
Feb 25, 2006
2,778
13
Long Island, Ny
while on the topic is it important for the ISC to have coolant run threw it? for instance will it automatically compensate when cold? Or just for that anti frosting effect like the throttle body?
Im asking unrelated to stock TCCS as im standalone but curious.
Same purpose as the TB, to prevent intake icing. It's automatic in the sense that coolant is always flowing through both to prevent it.
max-89supra(t)
153
vancouver, wa
oh shit!!!!!!!!!!!!!!!!
i thought that valve was supposed to be leaking!!!!!!!!!!!!!!!
thanks you slolved my life long supra problem!!!!!!!
my isc valve was leaking like crazy when i tested it!!
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
you really cannot "monitor" your pressure as you will always have a leak (open engine valves). The best solution I found was to pressurize the system through the turbo inlet and listen/feel for leaks. Just to be forwarned, the EGR vac modulator will leak (which i beleive it is designed to).
I used a 2.75" to 3" coupling,a clamp, a hockey puck (yes, thats right) through which I threaded a quick-connect air fitting.
suprafanatic
1,607
Greenwood, IN
well i got the new ISC valve in and the car still drives the exact same.. so im not sure it actualy helped. i need to do another boost leak test to see if its still leaking or not.
