I just did a boost leak test yesterday and couldnt believe how many boost leaks i found. I had boost leaking around the first two injector O rings, A leak out the screw on the BOV, a leak from a T bolt clamp, a leak from some Vac. T fittings. Then the biggest we found was coming from the ISC. As soon as we started to compress air into the intake it came right back out the ISC hose. The car would only hold like a pound of boost. So my question is, is the ISC suppose to leak boost back into the intake pipe? or is the diaphram behind my ISC shot? If its not suppose to do this where can i get a new diaphram? or what else could i do for now to fix this leak? I got all the others fix. Thanks
