Adjuster
For mine, I filled the Accusump, then plumbed it and mounted it. (And charged it so the gauge read 30psi.) Then before I started the motor, and before I opened the accusump, did the EFI fuse out crank for 10, then wait about 3 seconds, crank 10 seconds more, wait 3, then crank 10 secs, and it's showing pressure on the stock gauge, then put the fuse in, then turned on the accusump, watched the pressure gauge go up past 30psi, and started the motor..
Normal drill was turn the key on, click on the accusump, watch oil pressure go up, and then start engine. Should be minimal wear to bearings this way throughout the life of the motor.
BTW, with the sump "empty" after the oil change, I set the pressure to just 5psi holding the piston "empty" of oil. You can hear the piston moving around in the sump too from time to time, so there are times obviously when the oil pressure drops and without one, it could be doing damage to my bearings/engine.
