Depressurizing fuel system?
Fletch124
2jz swapped!
Jul 17, 2005
1,282
Reno, Nevada
Whats the best way to depressurize the fuel system? I dont wanna pull the line off and have fuel shoot everywere. I looked through the TSRM and didnt find much. I looked in my Haynes manual and it said to pull the EFI fuse. Obviously that wont work.
shaeff
Kurt is FTMFW x2!!!!
10
Around
let it sit overnight, it should bleed down by then. when you crack the fuel fitting, don't just spin it off, loosen it until the fuel seeps out and there's no pressure left. (and don't run the car right beforehand, as the exhaust will be hot, and that's not a chance i'm willing to take!)
Piratetip
Far From Maddening Crowds
1,177
69
MKE, WI
You can try turning off the fuel pump and cranking it a few times, loose the pressure through the injectors.
Fletch124
2jz swapped!
Jul 17, 2005
1,282
Reno, Nevada
Thats exactly what I was thinking of doing. But the car has sit atleast 15 hours so I think I will be ok.
