delete trc
1jzr32
Malaysia
Hi Mate
I'm completed my conversion but major problem on traction control. Runing till 3200 rpm only than misfire & I believe due to traction control on.
How to eliminate this trc ? Which wire to by-pass? Should I totally remove the trc butterfly valve.
Hope can get the info from u all. Thanks
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
i didnt have troubles with my trac in, but i started removing the traction control butterfly on a seperate throttle body i have, was pretty easy and i would recommend it if you are not going to use it, you just have to fill in the holes where you removed the unit.
unplug the traction control wires and try again, it might throw a code but it shouldnt have an affect on your car otherwise
tlo86
Jul 24, 2005
3,914
Colorado
crazysupra2JZ;984179 said:
to delete it? nothing, just unplug the harness from the unit.
did you get a code or anything? i honestly havent tried it yet Lol
1jzr32
Malaysia
1. trc delete - done
2. change 6x coil & spark plug - done
Still missfire at 3500rpm. I cant get diagnostic code due to not wired to my r32 cluster wiring. :icon_mad:
1jzr32
Malaysia
aphxero,
Te1 join to any ground from ecu (e1-e4) than +b to multimeter -(ve) & multimeter +(ve) to ig power ? m'i right?
