JustinGotA1j;1066361 said:
I see most people putting the water temp sensor in the upper rad hose on 1jz's. This is where I put mine as well and it works great for me.
Yeah I got it over there also!
The upper rad hose has the hottest water temperature.And the lower
rad hose has the coolest water temp...Is that right?
Now in the summer with hot outside temperatures when you push the supra
a little harder harder (not racing) what temperatures do you see?
And give me your oil temp also if you got any...
I got 92' C to 104 'C for the water temp.
And 96'C to 108' C for the oil temp.
Outside temps about 35' degrees Celcious.
I am at BPU (2jzgte) mode with stock new MA70 radiator,mechanical 2jz fan
and stock 2jz oil cooler.New thermostat,pump,hoses,rad cap and red coolant
from Toyota.
But DAMN...under the hood is getting very hot :aigo:
P.S. I got a big front mount IC which I think it blocks a quite amount of fresh air,and I don't have any secondary electric (condenser/AC fan) fan in use!
The stock twin fans did not fit with the 2jz setup and couldn't use them :icon_mad:
