i checked my codes for my bad idle,and 24,which is the intake air temperature signal,51 which is the air conditioner switch or neutral start switch signal.do If i got a different throttle body from the junk yard would that help the idle some.and the last code i read was ECT64,i don't even see a code 64.should i also reset the codes?
