dash harness question!
j3r3my
240
mass
ok i just picked up another mk3...an 88 5 speed turbo to be exact! well the PO hacked and alarm with remote start and BS! i want to know if i can use a 5 speed NA dash harness? whats the difference besides the volt meter on the cluster? anything at all? i want to buy a harness ASAP so any info helps
thanks!
If its the same year everything should pretty much work. Only differences would be the boost gauge vs volt meter.
Not quite sure on the differences between non abs cars and tems and such but generally how the wiring is done there will still be that wiring weather it was an option or not.
It's not like you cant make everything turbo work on a na anyways. All the plugs are the same.
