Damn starting gremlin!!!
gtsfirefighter
SM Expert on White trash
Sep 26, 2006
2,965
Had that isssue with my 86.5. It's the starter signal circuit. What we did, and I can't accurately describe it, was use a 5 prong relay, plugged the signal wire into it, then ran a wire to the battery, a ground, and the other to the starter where the signal wire is supposed to go. Fired up everytime after that.
aloshan
night ryda
Dec 7, 2010
349
Sydney, Australia, Australia
its called the 30 amp relay mod., once the wire from your battery to your starter is confirmed to be working properly , the relay mod should fix the problem
http://www.supramania.com/forums/showthread.php?76403-Car-not-starting-randomly-READ-THIS-%2830-Amp-Starter-Relay-Mod%29
it has for me, my car now starts first time every time.
