I NEED pics on what the wiring should look like when you bypass the lamp failure sensor on a mk 3, can anyone please help me? and what is the correct size of the wire tap squeeze connectors the last ones didn't cut the wire...
87M-GTE;1597560 said:Why do you want to by-pass it? just get a functioning tail light failure sensor.
I had to replace mine a few times, I think it was from bad taillight gaskets leaking water into the box.
you need the correct box as well, one is for the led 3rd taillight, one is for the regular 3rd taillight.
Sam
ma70;1598270 said:Where did you get your Lamp Failure sensor from?
Tony;1598408 said:My hatch used to leak also but it was coming from the rear tail lights. I used roof tar in a caulking tube and sealed them and havn't had a problem since. Got my lamp failure sensor off ebay for 15 bucks.
Supradupra.com;1597675 said:Link to guide to remove is HERE
Don't use tap squeeze, they are appalling! Tap into & solder the wires together for a 100% reliable joint, these are your stop lights after all :biglaugh:
The LFM circuit is just plain rubbish from day dot, same team must have designed it that worked on the cheese head gasket.... Admittedly water ingress does not help it's life expectancy but, to route the the power through such a module meaning all lights fail when it packs up is not particularly intelligent, 1 duff bulb is far safer than loosing all lighting IMHO.
If you want to help thats fine but there is a reason im asking and the reason is not because i want a smart ass comment to go with it.
Kai;1603000 said:I replaced mine with one from a previa - works fine. Search for it in the electrical section, there's a whole thread about it. Should just be a straight swap, but i know that UK and US electricals differ.
