I don't believe so unless you have a Canada model. The USA model both manual and auto tranny is black wires going straight to the starter relay coil. The neutral safety start switch is rated for higher amperage than the clutch switch. The clutch switch is designed to deliver low amps to the starter relay coil. So another words the clutch switch won't cut it. If it were me I would start right at the starter relay, which is on the passenger side kick panel and trace the black wire all the way across to the driver kick panel and cut it and put one side of it to the clutch switch and the other end to the other prong on the clutch switch. I don't know how else to explain it. Maybe someone else here can explain it better than me. Good luck.
