Custom fuel pressure regulator adjustable
jailbird25
53
Neugersdorf, Germany
:nuts: :nuts:
the aeromotive regulator is the biggest and cheap shit...
this is not the HKS regulator...HKS is not plug n play...the flow can control about a manometer and via Zeitronix....this regulator works perfect over 4 years in this car on ~5 Bar!
tte
Breaking In - in progress
Northern California
dbsupra90 said:
yes, thats exactly what i was trying to say.
there was a local guy that used vise grips on his return hose. it was adjustable too! if he needed more fuel pressure he just clamped them down harder. true story.
Lol...how cheap can you get?
Cheers,
Roy
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
I have to agree with him. Converting a stock regulator to adjustable isn't rocket science and there's no reason it should be any less reliable than an aftermarket one *if* it's done right. Fwiw back in the old days before we had all the goodies we have now I custom controlled my fuel pressure electronically using a Bosch frequency valve. That's an item older than the car itself. Worked like a charm and never had a problem.
Now vise grips on the return line, that's another story ;)
Mr. Y
80 miles away from Kremlin
here's mine...
It was modified by chief engineer on local factory. And it works fine more than one year already.
tte
Northern California
I like your idea of controlling it electronically...
Why did u ditch that setup?
Cheers,
Roy
Aspec
Supra uber alles
Dec 22, 2005
261
Surprise, AZ
The Smithsonian needed it for one of their displays.;)
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
jailbird25 said:
:nuts: :nuts:
Um, no. It's not cheap shit. I'd like to see a show of hands of how many people have had their aeromotive AFPR shit out on them. Now, take that figure and compare it to the number of failed modded stock fuel pressure regulators. ;)
Edit: and I'm not talking about a failure due to improperly installed SS fuel lines, the regulator itself people ;).
After a certain amount of rwhp you need xx flow in the return when closing the throttle and xx at full throttle I'm not sure of the internal construction of the stock FPR but I know Malpassi's have an issue with valve flutter above a certain flow.
I'm looking at this from a performance PoV and I'm sure the above mod is functional but at what point does it become unreliabe?
I wouldn't risk it on a high hp motor as one lean out can ruin your whole day.
