Custom exhaust fab question. (expeienced fabricators please read)
90T04
Tucson, AZ
www.azsupras.com
I have made lots of custom exhaust systems, hardpipes etc, and I am just wondering what you guys are using to cut the mandrel bends perfectly strait, yet at the required angles, to make a butt weld. I know there has got to be an easier way than how I do it. I have been using a marker to draw the line I need and then a cut off wheel on a grinder to cut it. I have thought about using a chop saw, but how are you going to clamp the pipe in there for the cut? I seems like chop saws are usually made for straight pieces of stock that can be clamped in the little vise.
I can get the cuts okay with a cut off wheel, but you always end up with gaps that you have to fill, big ugly welds, and then you get the poke throughs from the MIG wire, etc, etc,
A guy once told me you can get a piece of copper or brass sheet and make a little ring out of it and put it inside the pipe under the seam while you weld, and remove it when you are done, which seems like it would work, but the seam isnt always accessible when you are working with bends and long runs of pipe.
Anyway, just wondering how the pros are doing it.
Thanks
Ryan
dbsupra90
toonar
indiucky
well im by no means a pro, but it aint my first rodeo either.
we've always used a chop saw. the one i have the clamper is adjustable in width and angle. if its a tight angle you have to sometimes do one side then flip it over to do the other. if its a super tight angle you use a band saw. those are a little spendy tho, but real handy. if you dont have access to that the real tight stuff you'll have to do by hand. 95% of the stuff we've used a chop saw no problem.
another option is use a chop saw and section up the bends. thats time consuming and not crazy about how the multi sections look. but that works too.
here is a pic of a set of pipes we did on chris's car using nothing but a chop saw.
Slow66
I think with my dipstick
Apr 3, 2005
1,457
Newington, CT
The best way is with a band saw...bar none.
But since theyre so expensive, its not in the budget of most of us.....(ive been trying to save for one for a while now)
As long as the clamp on your bandsaw pivots, you can make due sometimes by usign angle cuts of wood to wedge between the guide and the object your cutting and clamp against it. You will still need to hold the piece whilst cutting, especially on the bigger diameter pieces. Even if you can just start the angle with the chopsaw, and finish it with the angle grinder, youll still save some time.
Thats abotu all i got :)
Facime
Leather work expert
Jun 1, 2006
2,716
Corvallis OR
well if ya end up with big ugly welds you can throw a flap disk on your grinder and grind em smooth. That at least helps with the appearence. I dont have a chop saw or a band saw (...yet, I will have one in TX though) so I do what you do and that is use a cut off wheel. I have gotten to be pretty good with the cut off wheel and can cut nice straight lines. Again if I need a little help, a flap disk can clean up my cuts a little.
Yeah, if I had my choice I would be using a band saw.
KevinM
Knowledge driven
Seattle, WA
Yep, on my first exhaust and IC piping setup, I used a bandsaw.
Now I have a chopsaw where I'm at and make that work. I usually just hold it myself which isn't the best, but I haven't made any big mistakes yet, and it doesn't take long to re-cut or replace if needed.
suprarich
Guest
Nov 9, 2005
2,187
ohio
Yep, self feed band saw here too. Works great. Then I clean up the cut with a vertical fixed position belt sander.
cjsupra90
previously chris90na-t
Jun 11, 2005
1,029
Lakeland, FL
I use a regular stand up Bandsaw but I have several jigs (wooden blocks with verious commenly used pipe sizes and radius's cut in to them to hold the pipe correctly) that I can attach to a aluminum plate the is guided by the table and allows me to get the angle that I want and ensures an exact and straigh cut
suicide
86
Barrie , Canada
i use a reciprocating saw for all my work and i grind my welds down to make it look better....
here is a pic after welded then grinded down, after this i will be painting or powder coating it... it will look perfect once completed,
and for IC piping i pressure the pipe to check for pin holes and go back re weld ad do on....
gixxer750
2jzget comingsoon!
Mississippi
the dewalt low speed bandsaw type thing is FTW. You can cut solid aluminum stock with it, pick it up immediatly without burning your hand, and it leaves very few burrs. It cuts steel just as well.
But yeah, I use a chop saw.
And I DON'T grind my welds down :) I've got far two many hours into making them look pretty to grind off
90T04
Tucson, AZ
www.azsupras.com
Im with you there, nothing like a good looking bead on your custom parts.
cjsupra90, that jig system sounds interesting, Id like to see some pics or something of how youre doing that.
Facime
Leather work expert
Jun 1, 2006
2,716
Corvallis OR
lol, yeah, I grind mine off.....cause they suck! Still learning. I can tack weld like a maniac though :biglaugh:
MK3Brent
Very expensive....
Aug 1, 2005
2,878
Greensboro and Greenville NC
Band saws are really the best way to do it IMO.
My chop saw likes to take alot of material out when it cuts.
Chop saws will also leave a LOT to clean up after.
Here are some example cuts I have made with one after cleaning:
You can even cut perfect angles too, like some mentioned.
