Probably not but that isn't going to help anything, and its not going to run if its a significant leak. Make sure there's water in the overflow, and don't remove the radiator cap until it has cooled down. How bad did it overheat? Make sure there's no leaks anywhere, was there any exhaust smoke?
The guage went all the Way up overflow filled but didn't dump water. It wasn't smoking and did not take but 2 minutes for fan to sit off and to take all the water back from overflow
Look for leaks, it shouldn't have been empty. Check the rubber plug behind the exhaust manifold, and the 2 elbows (one at the back of the head, one under the thermostat housing), those tend to get old and blow off or burst.
OP: All good suggestions and questions so far. We're waiting for some answers. Either way, let it cool down, and then see if you can limp it to safety.
