I did search, and found stuff for aftermarket turbos. Does anyone sell a turbo blanket for a CT26 that will fit under the stock heat shield?
THANKS!
THANKS!
Malloy;1107557 said:I did search, and found stuff for aftermarket turbos. Does anyone sell a turbo blanket for a CT26 that will fit under the stock heat shield?
THANKS!
tbcmorris;1107634 said:A better question is why run both? I see no added benifit.
Facime;1107638 said:Im guessing to get the benifit of a blanket and the look of stock.
Malloy;1108833 said:Duane, my hp goal is 1/3 your actual HP. I'm just trying to reduce heat and keep an OEM look, in a car that didn't have a 7M OEM![]()
