ct26 question
JesseH
1,153
Englewood, Ohio, United States
dont really worry about cleaning it out just with oil being through the exhaust side....the minute you start running it it will burn off fairly quick due to it getting so hot. both sides do come off, but if you've never done it before you can mess it up.
7MGTEsup
Formerly 'Down but not out'
Jun 14, 2005
614
England
Ha Ha some of the responses on this thread are classic. Yes the rear housing comes off, the best way to get it off is with some heat from a blow lamp and a hyde hammer. just heat it up all the way around the flange then tap all the way around with the hammer and it should come off quite easy. Just make sure you keep it square as your tapping it off or you will make hard work of it.
