Ok im building my own DDP,and im trying to perfect the sealing surface from the flange to the space between the turbine and wastegate port. Since my car is back in VA i cant check it myself and wont be back there for a month...i have all the other dimensions for the rest of the downpipe, but i forgot to get this one.... if someone has a CT26 laying around could you get the measurments that are highlighted in these pictures i found on ebay???
and also how far the wall sticks out would be nice....
If you have your CT26 out you probaly notice the wall that sticks out a little from the sides, about an 1/8" below the gasket surface, between the turbine and the wastegate valve. The measurements(from one side of the bottom of the wall, to the other, and from the bottom of the turbine port to the top of the wastegate valve) are the ones im having a hard time determining!!! Im going to do a FULL writeup and add all of my blueprints, as soon as i get done with it, so this could help everyone intereasted in building one. Thanks for the help guys!!!
