Still i ask my question whats wrong with the speedometer and tach?
and jw but what makes u use a sunpro boost gauge?
kamikazemkiii;1433688 said:Still i ask my question whats wrong with the speedometer and tach?
supranasty;1433757 said:In Your Video I see you have your Air flow meter attached . Are You are using the Maft Pro Speed Density ? Also what Cams are you using ? Do the cam Gears Help alot ? Im thinking of Cams and a VPC/AFC Setup......:biglaugh: Nice Numbers
wardog;1434315 said:SUPRANASTY If i could get low 12s with my set up, god damn would i be happy. Hey whats are your mods?????
kamikazemkiii;1434322 said:i just found it hard to believe u went from 50-120 in like 6 secs and how the tach droped back down in the 2nd video
but if its true then i bet that things breakin necks![]()
MRSUPRA;1435159 said:Was this on race gas or pump gas?
wardog;1435468 said:This was on 93 octane run. Stay tuned SPEC stage 3 clutch and Holset HX35 going in next weekend:icon_bigg Then im gonna hit the dyno again:evil2:
supranasty;1435478 said:Looks like your Tune is at 12.5 to 1. and 13:1 . Do you consider this a safe Tune ? Isn't this kind of lean for the AFR's ? No Race gas/No Methanol inj. Are you using Forged Pistons or coated ?
dbsupra90;1436178 said:you may try to do a free air calibration and see if it changes. was the dynojet sensor in the tailpipe?
mhopemk3;1437818 said:I think 20 inches is too close. However, I would also pull the WB o2 out of the pipe and do another calibration. Great #'s. I can't wait to put mine on the dyno with a T64.
