CT26 57 trim - safe psi?
pimptrizkit
thread killer
Dec 22, 2005
1,572
vancouver Wa
Most will say the safe psi rane is about 13/16 psi, put's the turbo in it's most effecient area, and create's good power and extend's turbo life.
though, i've seen up to 22 psi on mine, and when im driving mine i dont mind to see 18psi.
though she seems to want to build 10 psi and climb as rpm does..
theKnifeArtist
Fire on High!
Apr 6, 2006
2,332
North Jersey
Good question, i'm trying to experiment with my 57 trim as well.
I personally haven't gone over 8psi. heh
What kind of supporters are we looking at here?
gottadiesel
Flyin Low
Feb 16, 2009
459
Vancouver, Washington
I was curious of the same thing... I am running 16-17 psi right now, I have plans to go water/meth and 20psi, perhaps I am wasting my time and money without going to a larger turbo??? Has anyone else done a 57trim with water/meth? My AEM is set at 62% DC to get the 16-17psi, so I am assuming that with my setup I have room to make more boost, but as someone else mentioned, it does not mean I will net more HP/Torque with the extra 3psi of boost?
Safe all depends on your supporting mods.
Safe with supporting mods would be something like 17-18 psi
Safe without would be at fuel cut with stick afm
gottadiesel
Flyin Low
Feb 16, 2009
459
What are the risks of running more than 18psi? Blowing apart? Since I am just running 92pump gas, I have set my alarm to 17psi...
SupraSean
SPRASEAN MTHRFKR
Mar 3, 2009
487
Pittsburgh, PA
I Have had bad luck with anything over 14psi. i usually keep it at that or under.. they seem to wear very fast at higher psi.. I am basing this theory off of three turbo's.
8,897
tekdeus;1333141 said:
My 57 felt like all the power was at 15psi, and going higher made little to no difference.
The sweet spot is about 15-16 for that compressor. It will go higher with lower effeciency.
