ill Z said:CT26's? Wouldnt they be too big? The Aristo's are the US spec correct?
or you could weld the wastegate on the 1st turbo shut and run a single external.Bigzavs said:yup, CT20a's are also ceramic wheel
but you would have to make the y-pipe and wastegate the 2nd turbo like mentioned already
OneJoeZee said:Just go with a single turbo setup.
ill Z said:Sounds like work, does it even seem like a worthy conversion to anyone? Or should I look into an alternative TT, maybe even single turbo setup to reach the power band I desire?
I made 315whp@12psi, on a 1JZ with stock twins.........Rich said:My friend also has a 1.5jz and he made 345whp @ 14psi it has worked for over three years now and looks to be quite foolproof.
annoyingrob said:I made 315whp@12psi, on a 1JZ with stock twins.........
The rear turbo doesn't have a wastegate. Because the two manifolds are connected together, the 2nd turbo can also be controlled via the wastegate on the first turbo.tissimo said:I dont think you'd need to do anything custom with the rear turbo.. Iirc the front and rear wastegates have the same spring, so its fine
I just told you why he would have used two frontsRich said:well, there was a reason he used two fronts, maybe it was bolt pattern, I don't recall, it is about 4 years ago now
his username is youp, both here as on sf, if you search on that you will find the thread
