crower264 cams and idle problem not sure whats actually causing problem please read
CT26smoker
223
Houston
Good god, lash is not the same as cam timing.........
Did you degree in the cams, or not.
I suspect not, seeing you don't seem to understand what I and Rich are talking about.
You should take your car to someone with the tools to degree the cams.
I's a bitch to do in the car, but with a mirror to read the degree wheel with, it can be done.
supraking16
93
georgia
well i made friends with a guy around here with a 100 horse mkiv and he said he will help me with car so maybe i can get somewhere with it
FullNelson
574
Coastal Georgia
Be carefull listening to this guys advise. If his mk4 has 100 horsies, he probably did something wrong to it.
BLACKCAT
185
BHG
Try setting Intake to 0 & Exhaust to +2.
Reducing the overlap will improve idle quality but will increase your cylinder pressure.
These are my settings & it idles pretty well, but I have a aftermarket ECU.
