crossmember?
kwnate
Lurker
Jul 10, 2005
2,725
None of your fucking business
I believe the early 89's wont work, I have an 89 that has the square mounts. Save yourself the trouble and buy the mounts from BIC. Swapping a crossmember isn't the easiest thing in the world. At least I'd rather just put some new mounts on then swap out the crossmember.
Ken
350
Houston, TX
swapping out the crossmember is a pain in the ass. you will have to get an alignment after you've swapped it.
If you can get a crossmember for significantly cheaper than the BIC mount brackets and don't mind the labor involved, go for it.
Troyota
I Love What You Do For Me
Jul 28, 2005
243
Roswell NM
BIC Mounts FTMFCANNWTFWITW!!!!! (For The Mother F@cking Crazy @ss No Nonsense What The F@ck Was I Thinking Win!!!!!)
Evilempire1.3JZ-GTE
SF what a waste of supras
Jun 22, 2006
1,382
SoCal
Use the BIC mounts! really they are worth it most of the time the 1jz hydro mounts are cracked or broke anyways and they dont hold up to the hp and are no where near as cheap as the solid ones
You have less play with the solid ones it is an upgrade the bic mounts are around 150 each hydro mount is that and more. the solid mounts are in the 20$ range and even the used ones are almost never messed up.
I also heard you have more clearence for any 3" y pipe problems you will have with the non bic mount issues.
Big Rob
69
Melbourne
What is a BIC mount? And which crossmember can they be used with?
I am looking at putting a 2jz into my 89 GZ20 soarer which essentially has the subframe/ x member as a A70 chassis. I have a 1ggte so i guess it would be the same as a GA70.
jawsgear
Undergoing Construction
Jan 29, 2006
465
Sactown
www.jawsgear.com
Just changed the front cross member in an 89 and I have to say it is not all that hard. The whole process took under two hours to do and cost under $100.00. Solid aluminum mounts you can have made for $150.00 or so. Let me know if you need mounts Can have some for you in a couple of days.
