so you never took the cap off the res to see if there was atf swirling around showing that the atf was moven ?
this is one of the frist things to look for
Grimsta;1259076 said:/\/\ No, i did. It was, thats whats so bizar about it
Grimsta;1271450 said:I used a few cans of brake cleaner sprayed in the inlet and up from the bottom. Sprayed several times. I would spray, drain, spray, drain, spray, drain, let it sit for a little while then spray and drain again. Finally I sprayed a bunch and blew it out with VERY LIGHT air. If you just blow pressurized air in there you can destroy the screen
