Crankshaft " Pulley" ????!!!
noel
Uchiha Member
May 5, 2008
512
Miami, Florida, United States
OKay im a little pissed off right now ..i removed the harmonic balancer (starter trick) i took off the woodruff key i wanna replace the front seal but how do i take off the crankshaft pulley??? some one please help me!
Its on a 7mgte
noel
Uchiha Member
May 5, 2008
512
i used some Penetrating spray on the timing gear! nothing! the front lip of the timing gear came off from pulling on it so much..without removing the timing gear i cant get to the front seal
supraguy@aol
Well-Known Member
Dec 30, 2005
4,241
Atlanta
1james to the rescue.
And once you have it off, go to the Dealer, and grab yourself a new replacement. You don't want to put the damaged one back on.
That puller will not take it off.
You need the one with the 4 slots.
Those come off from time to time from old age. Bet to get a new one or a used one and permentally weld it better. Like with a tig.
1James
Lurker
Mar 19, 2009
60
Bay Area, CA
noel;1999425 said:
View attachment 72376which pulley removal tool did u use? i did see the 2 holes which look very small... i just a claw)tripod looking tool(in the picture)
It is something like this:
Bolts go into the holes into your pulley and turning the center bolt on the tool pushes against the crank snout and pulls out the pulley.
noel
Uchiha Member
May 5, 2008
512
thanks everyone for the help i will get the correct puller..i really wish i didnt have to change the gear..all cuz of the lip:cry:..i saved the lip maybe i can put it back on the gear.
noel
Uchiha Member
May 5, 2008
512
DeadlyWrenches;1999508 said:
That engine must have been beat on pretty hard, because mine came off by hand.
what would cause the gear to be so stubborn to slide off the crankshaft???!!:: angry :: the harmonic balancer i can understand..but the timing gear???
