I was under my car today while it was running, and I could see some runout/wobble in the rotating crank pulley, not sure, maybe 1mm? This engine in the past has had the bolt come loose and damage the key way. I checked it today and it was again needing to be retightend (wasn't loose enough to cause problems yet).
I've been revving it to 6000+ rpm with the new turbo. Recently the front main seal has starting to leak a bit. Any tips on what to do here?
