crank pulley bolt
Kevin
7mgte -> 7mgte swap done.
Apr 20, 2009
865
Windsor Ontario Canada
gaboonviper85;1508622 said:
just pull the oilpan off and jam a 2x4 between the crank counter balance and the inside block wall....then use a pipe over a wrench to break the bolt loose...real easy stuff.
what do you guys think of this method?
Heavy D
358
worcester, ma
im gonna try using the starter, just to make sure does the crank pulley spins clock wise? havent tried yet since i left the state, at New Hampshire at the moment, but ill try it once i get back tomorrow.
WhtMa71
D0 W3RK
Apr 24, 2007
1,813
Macon, GA
Yes. Put breaker bar on, lay it on the ground (drivers side) and bump the starter.. Should bust it loose fairly easy.
Heavy D
358
worcester, ma
it cool, it came off, thanks, never did it in the first place cause of how it spins counter clock wise i thought i would snap the bolt by trying to use the starter, most of my 4 banger cars like my starlet turbo motor and corollas are clock wise and came off easy.
Moy
It's broken...
Aug 6, 2008
2,432
Beach Park, IL
ForcedTorque;1508661 said:
Confused on your method here, but good info on the pulley holder.
What I meant is that it would be easier to break the bolt free using the pulley holder out of the vehicle because there is more room. However, when I did used the holder on my engine when it was in car, I braced a breaker bar against the frame of the vehicle to stop it from moving counterclockwise (in direction that I was pulling to break the bolt free)
