Ok, just wanted to be sure. Im still stumped, would a sound clip help figure this out at all? I dont even know what else to test
socc924 said:Ok, well a few more things. When I first went to start my car this morning all it would do is crank. So I went under the hood and played around with the wires going to the coil pack and the ones going to the cps. Sure enough it fired right up. I wish I did each individually to pinpoint the problem.
I just check it and there was a code 12. Then I cleared them and I dont get it anymore. Also... as a side note, its normal to get code 51 when you rev the motor while checking the codes at the same time, right?
socc924 said:I also hooked the egr directly to vacuum and the car immediately stalled.
socc924 said:Thanks so much guys, I realy apreciate the help. I will do what ever I can when I get done with work and school today. Now, when you rewired the cps, did you just run wires from the ecu to the cps directly? Thanks again.
