I am finishing a build on an '89 turbo. I managed to get the car running, though not well: it would not idle, and would run quite lean under throttle. Upon trying to adjust ignition timing, I discovered the CPS range of motion would not allow anywhere near proper ignition timing. I checked the CPS driven gear alignment and found it was off. I restabbed the CPS, per the TSRM, and now she won't start at all. I get sputtering and a few deafening backfires. I have rechecked the alignment twice with the same results. I rechecked spark, fuel delivery, and vacuum system. I am suspicious of the CPS. Is it possible for the CPS to suffer an internal alignment failure? If so, what's the fix? I have tried the wire wiggle thing to no avail. Any help is greatly appreciated as I am about ready to put a bullet through the block and buy a bus pass...
