ok car is getting fuel and spark but doesn't stay running it just backfires a whole lot. Now I think I remeber Hearing that the CPS has to be installed a certain way? after rebuilding my motor I just slid it into the head and plugged it in.
GrimJack;937002 said:Correct. You need to use a wrench on the front of the main pulley bolt to put the engine at Top Dead Center, then pull out the CPS, align the dot with the notch, and put it back in.
eman2289;937035 said:What confuses you? Ill explain to the best of my ability.
