New Q's: Who knows the confirmed open loop percentage?
I'm estimating to setting my Hi throttle to 40% and leaving the low at default of 10%
Also... I've only run the car wot in 1st and 2nd. If i tune the safc for those gears will 3rd differ much? I noticed when my car was running previously that i wouldn't hit fuel cut till 3rd gear so that suggests more air. If i try to street tune 3rd n 4th gear i would be doing excessive speeds and i'm not overly comfortable doing that
Thanks for any help
When you first selected your settings for the safc so the car would start do you remember what your max voltage was for the tps?
When you change the monitor settings to view throttle position do you remember what it said when you went full throttle (ign on only of course, kinda hard to watch that when actually going wot hehe)
My voltage at wot is 3.4v and the first time i viewed the tps when closed and open my wot was only 69%
I went into the etc area and did the closed for 10 secs and open for 10 secs a couple of times but made no difference.
I go back into monitor view and decide to just hold my foot wot forever, eventually the safc wound up to 100% and seems to be remembering it. If i open the throttle slowly when i reach max it's only 97% ish but that's better than 69% lol. When mashing it immediately goes to 100%.
So does everything sound ok? I thought the tps went to 5v when wot?
Thanks for any help
