how will you know its bad?anything i can to check it? i know the current turbo thats in my car is its 2nd turbo. it was installed at toyota dealership in early 2000's. i have the reciept, and its a reman.
Supracentral;1832863 said:Sorry, it's turbo jargon = center housing rotating assembly
It's the part of the turbo that isn't the compressor or the turbine:
no i havnt checked for a leaf down test. i probally should do one,to find out if im leaking anywhere.harley1985;1832873 said:hmmm suspect. thats awefully white smoke. did you do a cylinder leak down test? check it out
http://www.carcraft.com/techarticles/116_0406_cylinder_leakdown_tester/viewall.html
