If possible could someone who has a jz motor with 90 or newer mkIII please measure the distance from the center of the rubber mount bolt to the flat back surface of the block that mates with the tranny. (In my case a 1jz bellhousing with a r154)
I'm suspecting that the custom mounts I had made are not infact the correct distance for properly mounting this engine. I suspect that they are forcing the engine upagainst the firewall to far by about 1" or so.
Thanks in advance for the help.
