correct way to run an aftermarket bov
89supra7mgte
797
colorado
No there is no egr it was capped by po. Not sure if it is jdm or not any identifying marks that will tell me? Just has the one port, that only has vac on throttle. but i also have the port on the manifold to the boost sensor, which has vacuum at idle and decel .
Victor Charlie
161
Ann Arbor
If you are not using EGR I don't think it matters.
89supra7mgte
797
colorado
Heavy D;1437230 said:
^^ vacuum port? should try to use it from the manifold, that way the BOV can open up faster, than the throttle body
Thats thing i guess i need to see which works better when its running, the tb and manifold act different with vacuum they are almost oppisite eachother.
