^so you have the rear on top ring and front on middle? or do u mean middle all the way around?
Rob_Supra87 87NAPWR Aug 3, 2008 278 0 16 Millbrae Jul 18, 2010 #21 ^so you have the rear on top ring and front on middle? or do u mean middle all the way around?
S SrBigbutt New Member Apr 26, 2009 340 0 0 45 Spring, TX Jul 18, 2010 #22 I have the front on the middle ring and the rear on the bottom ring.
Poodles I play with fire Jul 22, 2006 16,757 0 0 43 Fort Worth, TX Jul 18, 2010 #23 It's leave the perches at the highest level personally, since the eibach springs already lower the car. It's actually a "retention" ring IIRC and they use different pliers than snap rings. Normal snap ring pliers will break on those...
Rob_Supra87 87NAPWR Aug 3, 2008 278 0 16 Millbrae Jul 18, 2010 #24 if I were though to want to change the rings settings for the front would I have to take them off again? ---------- Post added at 02:45 PM ---------- Previous post was at 02:44 PM ---------- ^take off the spring/shock combo I mean? so would lowering the ring do anything lower wise? would it give better handling?
