cooling..
Supracentral
10
I'm not going to debate what's "better" -- however coolant provides:
Higher boiling temps
Anti-corrosion protection
Lubrication for your water pump
Those are reason enough to run some form of coolant (be it water wetter or an antifreeze compound) in the system.
On my road course car (the MKIV hardtop) I run water wetter in the summer and Toyota Red in the winter (both with distilled water).
I think you need to read a very important thread that was a link to the link in this thread,
http://www.mkiiitech.com/forum/showthread.php?p=4351#post4351
Great info. 50/50 is basically what you need. You can run 60/40 depending on application and ingredients. But basically 50/50 toyo red or other with distalled water is what you need and all you need. And never run 100% water esp tap water. Tap water is what gives your rust.
Edit: my info was for street. Do what you want on track and most tracks prefer water only. for clean up.
super.secret.supra.club
1,304
San Diego, CA
it is, but the fluid cooling a 2 stroke is still the same way fluid cools a 4 stroke. the temps they run is around the same that we do. im trying to find that damn article but i just plain 'ol suck at searching. i wish i would have book marked it.
There are 2 strokes that dont ryun coolant even and they dont take the abuse a car engine does.
I see where your getting at and i have prolly read the link before.
Its kinba like break in info with motoman with hard break in vs ol skool slow break in. Tho every manufacture out there has a a 50/50 coolant and it works not matter what in everything but substantial climates. I worked on test cars and they would test everything in coldest climates and hottest. Stock off the lot and recorded and tried to improve off the other cars finding from say for or chevy or nissan or toyota.
Falken
294
Los Angeles
cool thanx alot for the info guys... well ya i live in palm springs its cold for now but summer time comes around ew lolz
Me you and sssc all live in cali. 50/50 is all you will ever need.
I dont have the time or money and the fact i just bhg after 55k and 45 ksince i owned the car in 2.5 years plus i work 6 days 10+ hours a day. 250k on the car and i didnt do the rebuild.
