You've had tons of suggestions in this thread. Maybe you should check those.
M mkIIIman089 Supramania Contributor Mar 30, 2005 3,061 0 36 Ohio Sep 2, 2007 #21 You've had tons of suggestions in this thread. Maybe you should check those.
I IJ. Grumpy Old Man Mar 30, 2005 38,728 0 0 62 I come from a land down under Sep 2, 2007 #22 10 blade Toyota and a new Genuine GTE Clutch.
turbotrev Goin WEEEEE on my gsxr600 Aug 7, 2006 311 0 0 37 Clinton, MO Sep 2, 2007 #23 so stock hardware will be good for the roadracing on the 1jz?
M mkIIIman089 Supramania Contributor Mar 30, 2005 3,061 0 36 Ohio Sep 2, 2007 #24 IJ. said: 10 blade Toyota and a new Genuine GTE Clutch. Click to expand... IDK if he can do that on a 1J...IJ.
I IJ. Grumpy Old Man Mar 30, 2005 38,728 0 0 62 I come from a land down under Sep 2, 2007 #25 Nothing comes close to moving the amount of air that the 10 blade will Trev. You're not chasing the last 3hp you need reliability and a safety margin.
turbotrev Goin WEEEEE on my gsxr600 Aug 7, 2006 311 0 0 37 Clinton, MO Sep 2, 2007 #26 aight IJ i see were youre coming from! i never intended to make goobs of hp i was goin for reliability and weight loss will 7m blades fit on 1j
I IJ. Grumpy Old Man Mar 30, 2005 38,728 0 0 62 I come from a land down under Sep 2, 2007 #27 2 x e-fans will sit further forward so will have more effect on handling/weight than 1 mech fan bolted to the pump (I'm really NOT a big e-fan fan)
turbotrev Goin WEEEEE on my gsxr600 Aug 7, 2006 311 0 0 37 Clinton, MO Sep 2, 2007 #28 so e-fans will be better for handling but not better for cooling?
I IJ. Grumpy Old Man Mar 30, 2005 38,728 0 0 62 I come from a land down under Sep 2, 2007 #29 Nope the e-fan will be worse/worse
turbotrev Goin WEEEEE on my gsxr600 Aug 7, 2006 311 0 0 37 Clinton, MO Sep 2, 2007 #30 ok i got cornfused lol also the 10 blade and 7m fan clutch will fit on the 1jz, right?
I IJ. Grumpy Old Man Mar 30, 2005 38,728 0 0 62 I come from a land down under Sep 2, 2007 #31 Dunno Trev one of the Jz guys should know though.
turbotrev Goin WEEEEE on my gsxr600 Aug 7, 2006 311 0 0 37 Clinton, MO Sep 2, 2007 #32 thnx for the info IJ ill ask one of thems trev
OneJoeZee Retired Post Whore Mar 30, 2005 5,721 0 0 38 aboard the Argama Sep 2, 2007 #33 You can use the 2JZ waterpump and fan.
I IJ. Grumpy Old Man Mar 30, 2005 38,728 0 0 62 I come from a land down under Sep 2, 2007 #34 The 1jz may not have enough torque to turn the 7M 10 blade
turbotrev Goin WEEEEE on my gsxr600 Aug 7, 2006 311 0 0 37 Clinton, MO Sep 2, 2007 #35 ^^^ lol and thnx again IJ and OJ
OneJArpus Supramania Contributor Jul 1, 2005 2,798 0 0 41 Newark, New Jersey, United States Sep 3, 2007 #37 lol OJ!
