ok... i have an 87mk3 with a JDM Engine and 3inch turbo back exhaust. and the coolent overflows when i park. Its not a BHG. cause there is a new one on there. the head is shaved and i have a higher compression so i have to run 93 plus a bottle of octane booster.. Its not a thermostat, cause i was just replaced, and its not the radiator cause it was just replaced. my electric fans are wired to a switch cause i didnt have enough money to get the temp sensor or whatever its called. so when the temp gauge (aftermarket) says 160, i flip the switch for the electric fans. and after i park the car some coolent still bubbles out when i have the fans on. i could only think of 3 things, 1. radiator cap is rated for 13lbs. 2. i need a fan shroud for radiator. or 3. i forgot what 3 was but ill remember if anyone has any suggestions... thanks
Tom
Tom
