DFISH85;1164237 said:
ok i dont have a leak down tester/block tester, but i did check the o2 sensor and it was all white and when i pulled the spark plugs #1 and #2 were covered in oil. these are usually signs of a blown headgasket right?
im not really sure what kind of headgasket it has right now but its probably just the stock one. i already started pulling everything off to get the head out so i should know soon.
Well now you have a little of an idea of what is the problem. I blew my head gasket, and you would think you would have more coolant in the cylinders, well like you, I had oil in the cylinders. I took a cue tip with an wood kabob stick and went to each cylinder. I had more oil in there, but also coolant. I am sure you blew a head gasket.
Remember though, once everything is torn apart, have a shop inspect it, the worst thing you could do is tear it apart, and then put it back together and still have issues.
Also when my HG blew I am not sure if it was before I owned the car ( I had it blow up on me the night I bought it ) 62-1 full 3" blitz, HKD FCD ( Pile of shit ) Blitz filter, cooleeze DP, coolze intake, stuff like that and it blew a compression ring the 2nd one.. I have no idea how, or why.. it may have been like that when i bough it, but yeah check everything.
