coolant over pressurized?
7mpheonix
7
fayetteville, ar
ok, I have a 1989 supra n/a with a head gasket that didn't seat correctly(previous owner). I've only had this car for about 3 weeks now and occasionally after driving it and getting it up to temp. when I put it into park and turn off the engine, coolant starts flowing out of the reservoir tank. it also seems like it's boiling in the reservoir tank. now could this be caused by the head gasket, or am I looking at another problem? the car does over heat occasionally, but I'm positive that the over heating is directly caused by the head gasket.
Ozz89supra
Ozzy
Feb 22, 2009
167
Phoenix
Mine did the same thing all the time. It turned out to be a clogged radiator, I bought a new one and the problem was fixed. and I live in Phoenix so It's hot as hell here :cry: and it does not get stupid hot anymore.
7mpheonix
7
fayetteville, ar
well, the weird thing is that when it happens, the engine isn't overheated it's at normal running temp. I know the gasket is a big problem, and I'll be fixing it soon, I just wanted to know if this is a problem associated with it or if I need to fix something else while I'm in there.
7M-KDL
Seeking high numbers
well like ozz said, it could be your radiator. i think the first thing i would do is the head gasket and hoses and thermostat...i was actually having a similar problem and will be pulling my motor in a week or two to fix all my problems. which include head gasket, hoses, some other gaskets, thermostat, water pump, timing belt etc. a motor rebuild actually. and you may not need to do all the but, something to consider i guess. also, you can get a cooling system pressure tested from most auto parts stores as a rental to determine if you system is leaking and letting air in which can also cause overflow. good luck and hopefully this helps
88guy
use to go 280KMH :(
Jun 13, 2009
180
Victoria BC Canada
Get the cooling system fluished 2 or 3 times. May solve the problem if not....your rad could be doneskis. Just trying to think outside the box.
iwannadie
981
gilbert, az
I had the same thing when I had BHG, it was like exhaust gas was getting into the cooling system. The coolant looked fine, oil looked fine and didn't over heat.
I would try a new radiator cap as its cheap and who knows how old it is now. Then later look at switching out the green coolant with toyota red or whatever other acceptable(cheaper) replacement, as recommended by the smart people on this forum.
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
Your gauge might not be working, if the coolant is boiling, it is HOT, and your gauge is obviously not showing it
LOL i like how all the Az people are posting in here
88guy
use to go 280KMH :(
Jun 13, 2009
180
Victoria BC Canada
Clearly you guys have some experience dealing with heat :p When summer strikes the rest of us start scrambling to keep our supra's cool. You az guys must laugh lol
CFSapper
AKA Slient_sniper
Apr 24, 2006
796
Chilliwack
if you have the tools do a compresstion test on it with the rad cap open if you see water shoot out your rad cap almost gerrinteed BHG thats what happend to mine anyway
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
get a BHG tester from napa or wherever. ive seen cars with little to no symptoms blow their motor from a bhg.
Ozz89supra
Ozzy
Feb 22, 2009
167
Phoenix
lol yeah this forum is active :love: Azsupra is kinnda dead sometimes, but I still like it nonetheless..... I like your sig. VATOZONE!! hahaha
dumbo
1,911
Albera, Too Far North
How do you possibly know that?
Second, that means exhaust gasses are getting into your coolant, or your system needs to be burped, which could explain you over heating also.
Compression test, and the exhaust gas tester.
New oil as in the PO just changed it? Are you loosing coolant?
7mpheonix
7
fayetteville, ar
ok, so I was going to replace the head gasket this weekend, but last night as I was driving home I noticed the smell of gas. I popped the hood with the car running and gas was spilling out from somewhere on the intake side of the cylinder head. I'm not talking about a small leak, it was gushing. after letting the car sit for about 45 sec. I already had a puddle of gas under the car. It was dark, so I couldn't see exactly where the gas was coming from. Also, it was a bit hesitant to start, although it did start after I gave it some gas. do you guys have any idea where this huge leak is coming from?
