Coolant leaks out of the overflow
Eamon
98
USA
^that's what the guy at the radiator shop did and nothing happened.
---------- Post added at 02:17 AM ---------- Previous post was at 02:10 AM ----------
whitemike;1592358 said:
Nick,
He obviously doesn't need our help..
Umm... If I didn't need your help would I be posting here?
Eamon
98
USA
S.A. supra;1592487 said:
I thought you said some kind of machine. How about a new radiator cap
Ok i'll get one today. Sorry if i'm being unclear it's just this is my first car and I'm still learning.
whitemike
1,164
Winter Park, Florida, United States
I'd suggest trying what people are recommending then. You're asking for help, people are replying, and you're taking your own steps and leaving their suggestions untouched. That's all I meant by my comment. Nick usually has very good advice, so I'd check out what he has to say..
-Mike
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
He probably used a 5 gas analyzer to sniff the filler neck in the radiator. I would still try the Napa Block test kit and do a cylinder leakdown test, that will verify if there is a problem. As soon as you pressurise a leaking cylinder the coolant level in the radiator will rise or bubble.
We can understand you dont know too much about cars etc but doing some of your own research can go a long way, instead of asking us "where would the hole be?". Really? Do you really think we can tell you where in your reservoir there is going to be a hole if there was one? We are not pyschics here.
Eamon
98
USA
Ok I think I figured out the problem. It appears that the coolant resevoir cap came off of another Toyota car like a Camry. On those cars, the overflow hose was on the right, and on my Supra the hose is on the left. So I just turned the cap around and now it doesn't leak anymore.
Could there still be bigger problems though?
8,897
bombinuass;1593544 said:
lol ^^^ sometimes i feel like i just get on here for a good laugh lol
You mean like how a Supra owner can screw up an engine hoist? Not that I am picking on him, but I laughed when I read that topic.
I don't know what the problem is, so how can you suggest what part he may need. I gave him the benifit of the doubt that the resevoir was leaking, because it came out at the fill line which is about half way. If he is over heating, it will just pump out of the resevoir because the resevoir is not sealed.
Eamon
98
USA
It doesn't leak out of the overflow anymore now that the resevoir cap is turned around. Also I don't think there was a hole to begin with. All I'm wondering is if there are any hidden problems that I should look for...
89supra7mgte
797
colorado
It is kinda hard to determine if there are any other problems with car without knowing anything other than your reservoir leaking? Does your car overheat? does it run rough? What you need to do is follow the the advice in the thread. Compression test, leakdown test, block test, coolant pressure test and so on. If all passes then you might not have bhg, but dont rule out the possibility.
